Hi
Can someone check my wiring harness on my vin to see if there is already a plug to connect the front parking sensor harness in my car? I already got rear parking sensor from factory. my vin is VF7**************[VIN obfuscated, can be read by forum staff]
thanks
Citroen c4 b7 , retrofit front Parking sensor?
- x 6947
Re: Citroen c4 b7 , retrofit front Parking sensor?
I doubt it, as there are 47 variants of main front engine harnesses and the harnesses that had front obstacle detection have specific harnesses. So there may not be a compatible loom in place and there are too many variants for me to check for a car that does not have this option fitted at factory.
Also the Parking assistance ECU will be different too.
yengec21
Hello ,
Same i have same request as amigo , Could you please share the sensors ,brain etc of front parking sensor system?
- x 6947
I've sent you a PM on this from my point of view.
