3.0 Xantia misfire
Stempy
3.0 Xantia misfire
Well since replacing the thermostat and spark plugs it's like a different car and runs up to temp quickly as it should and is much smoother. However, it still has a rough period between 1500 and 2500 rpm especially bad at just over 2000rpm. It is much worse when cold but it's still noticeable very slightly when hot. There's nothing wrong with the performance otherwise.
On the back of the throttle body there's a cylinder which Citroen call a 'compensator'. I assume this is an air bypass valve but don't know how to test it as it is completely sealed.
I'd be interested to know if anyone knows any test procedures for the various input sensors for the injection ECU, and where the diagnostic plug is situated so I can perhaps read any fault codes.
Richard Gallagher
The diagnostic socket is the long 30 pin one in the fusebox where the handbook is kept. You will need a proper code reader, the LED type will not work as 'pulses' are not generated.
If I'm not too far away from you, Iver Bucks (M25/M4/M40 triangle) you are welcome to 'pop in' and I will put my Sykes ACR on it. This will not only read fault codes but also give the "readings" that the ECU is receiving from the various sensors, such as temp(coolant/air)/ignition timing etc etc.
philhoward
Stempy
Stempy
Richard Gallagher
XM-V6
Richard Gallagher
Stempy
Richard
They all sound like four cylinder engines.
I did find the diagnostic plug in the cabin fuse box.
I believe engine management is a Bosch MP7.0
XM-V6
This is more that just sounding rough, there is a definite hesitation and stutter in the acceleration. Being that it is much worse when cold I'm wondering whether one of the temperature sensors is playing up and affecting the fueling. Though I've heard that MAP sensors and the TPS can go dodgy. What ever it is, it hasn't been enough to make the warning light come on, but it may have registered a fault code.
XM-V6
Richard Gallagher
deelite
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stempy</i>
Hello Stempy,
I once had nearly the same problem with my V6. It was running bad between 1000 and 2000rpm. When the car was diagnosed with running motor on the Lexia computer, 2 faults appeared : idle speed motor fault and temperature sensor fault. The idle speed motor is the air bypass valve connected with the orange wires : http://xantia.servepics.com/picuploads/ ... c-472s.jpg
When you loose the connector there are 3 pins. From left to right you should measure on the pins 3 and 2 12 ohms and on pins 2 and 1 10 ohms. Mine was dead, so i replaced the unit. Sometimes the valve is blocked by dirt, so you can clean it with WD40 or something.
The temperature sensor was worn to, since the computer diagnosed -45°C with a running warm motor ! So the injection received bad values.
The sensor have a green connector and is placed underneath the airfilter box on the waterhouse. The enigine management is Bosch MP7.0. I got the diagnosis procedure in PDF-format and French language and can send it by mail if you want it.
Hello Stempy,
Richard Gallagher
Stempy
Thanks deelite and Richard. I think the next thing I am going to do is carry out voltage and resistance checks on the various sensors/actuators etc to see if that throws any light on the problem.
Richard, if you sent a mail via the forum it's likely that won't ever leave. I have had problems sending and receiving mails from the forum in the past. My email is [email protected], if I get no joy with my static tests I may well give you a call.
Stempy
I've narrowed down the poor running to the point where I can predict it is going to happen, and that is at low engine speed, ie below 2200 when under load, generally accellerating slowly up hill. Any ideas wouls be welcome.
I haven't forgotten you Richard, tried you a couple of times but didn't leave a message.
