Hi all
Just thought I would post an observation I made this morning.
I was turning my 2009 diesel C5 round in a car park earlier today and saw smoke in passenger door mirror.
I thought I would rev the car to see if it got any worse and to my surprise the car would only rev to around 2500 rpm, I thought something was wrong with the car until I took it out of gear and it revved normally.
The smoke turned out to be condensation the reduced revs must be a built in safety device
Any other opinions?
Regards
Steve
Reverse gear
Onlinemoizeau
- x 423
Re: Reverse gear
My 16v 1.6 hdi 90 won't rev past 2500 in neutral, not checked it in gear with the clutch pressed. I presumed it was linked to a speed sensor to stop you revving the balls of it. At least you don't have to worry at MOT time.
Pete
Steveo
- x 13
Re: Reverse gear
Hi
Never thought to try it just with the clutch down
I thought it was because it was in reverse with clutch down.
I shall investigate
Just checked
Clutch down car revs normally
Reverse gear and clutch down 2500 rpm
So reverse gear only
Thx
Steve
I shall investigate
Just checked
Thx
Steve
Datadogie
- x 8
Re: Reverse gear
DPF regeneration with Lexia puts it up to 3750 rpm in neutral.
