tires and led lights
habo
- (Donor 2021)
- x 5
Good Evening
Tires, which do we prefer 93 or 97 XL? to a C4 Grad Picasso?
Now it wears 97 XL just like when I got the car, but I was wondering if the 93 has softer sides and so I have less noise from the rear.
Has anyone installed low beam philps led lights? do we need canbus adapters?
- x 1942
Re: tires and led lights
I have fitted Philips Ultinon Xtreme LED H7 bulbs in our Peugeot 308's dipped beam. They do not cause any warning lamps or messages on the dashboard but they do store errors in the BSI. Maybe canbus adaptors would stop these errors but as they doesn't seem to cause any problem why bother?
Philips have introduced lower cost LEDs in the last year or so and I don't know how those behave.
- x 6946
Surely these are still not road legal to install into Halogen lamps....
habo
- (Donor 2021)
- x 5
Paul-R thanks, a friend put the Philips H7 Ultinon Essential Led 12V 24V 20W 6500K in a C4 model 2013 and they are fantastic, they did not need adapters and we tested at night, I drove against it and saw that they do not dim (but they were perfectly adjusted ).
But I would also like an opinion from someone who has put in GP.
GiveMeABreak I know they are illegal just here in the (-expletive removed-) where I live they are full of everything, cars and tractors with Chinese leds, which shine wherever they go. It's a war and I have to defend myself.
Does anyone have an opinion on the 93 vs 97 XL tyres?
grizzlycx
Be aware - now not legal for MoT - at all. Also tyres over 10 years old.
Xantia V6, BMW 740, Maserati 3200GT, Honda CBR1000, XLR600
had 7 CXs, 2 XMs, 3 Xans, 1 DS, 2 205gti
Where is that cheap lovely SM?? And have you noticed that the French do not make proper motorcycles?
habo
- (Donor 2021)
- x 5
I live in Greece .
I change tyres every 33,000 miles or every 4 years , about
- x 6946
I think Greece is still in the EU last time I checked and the same law applies, so be aware if you have an accident and are caught with them - insurance may decline to pay as an illegal mod..... Your choice, but we don't condone it on the Forum.
As much as my lights are dreadful in the Aircross, the first thing I did was upgrade the bulbs to road legal brighter halogens. I know I'll get a shorter life span out of them, but at least they are brighter than stock bulbs.
- x 3565
To clarify for anyone wondering why all the fuss about LED upgrade lamps - one of the main issues is that road use approved halogen lamps all have their filaments in the same position. An H7 lamp made by Philips will have its filament in exactly the same position as one made bt Ring as one made by Osram. Headlamps for use with halogen lamps will have their reflectors designed to utilise that filament location. LED lamps can have a somewhat random positioning of emitters which can wreck the headlamps beam pattern.
- x 6946
I'll just quote the updated Rules March 2021 here in the UK:
Current
Current
Changes:Section 4.1.4 of the current MOT inspection manuals for both motorcycles and cars and passenger vehicles states ‘Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.’
Class 1 and 2 motorcyclesFrom 22 March 2021, we’re changing these rules so that not all motorcycles and vehicles will fail the MOT test if their halogen headlamp units have been converted to be used with HID or LED bulbs.
Class 3,4,5 and 7 vehiclesClass 1 and 2 motorcycles must not be failed for the defect ‘Light source and lamp not compatible’.
Headlamps must comply with all other requirements of the test and headlamp aim.
The motorcycle inspection manual will be updated shortly, and the ability to select the defect within the MOT testing service will be removed.
For class 3,4,5 and 7 vehicles, the defect ‘Light source and lamp not compatible’ only applies to vehicles first used on or after 1 April 1986.
Should a vehicle be presented for an MOT test with conversions before 1 April 1986 they must not be failed with immediate effect.
Vehicles presented with converted halogen headlamp units first used on or after 1 April 1986 will continue to be failed.
The cars and passenger vehicles inspection manual will be updated shortly.
habo
- (Donor 2021)
- x 5
bobins are both right and wrong. OSRAM has started the process of certification of old car models with led lamps
Here are the ones that have been certified so far that they can use led .https://www.osram.com/am/campaigns/vehi ... /ledcheck/
So there are halogen reflectors that can accept led.
It is a matter of money to check all the old models. And if it is certified and legal in Germany it is legal in all EU countries.
An opinion on tyres; has anyone put in GP 93 load?
- x 6946
Not correct - see the small print in your own link Habo:
I had to counter your post with this info as it can be misleading to others
Being compatible, does not mean Legal, hence the disclaimer and clarification that your insurance will be null and void.....1 These products do not have ECE approval. This means they must not be used on public roads in any exterior application. Use on public roads leads to cancellation of operating license and loss of insurance coverage. Several countries do not allow sale and use of these products. Please contact your local distributor for information on the availability in your country
Gregor
- x 16
As seen on OSRAM website, some of their LED H7 are legal to use on some car models in Germany, Croatia and Austria. The rest is still illegal use.
Driving Citroen is a diagnose!
- x 6946
But did you actually look further Gregor? Once in the country listing, they show the actual cars that have approval - and for PSA they have the grand total of ....... 2 vehicles!
We have....
308, Boxer /Jumper
and that's it.
We have....
308, Boxer /Jumper
and that's it.
Gregor
- x 16
Hi I said on some models only. But I believe list will improve-grow in near future
- x 6946
Yes, let's hope so - and nothing yet for the UK....
I shall be in the market from some LED conversions, as I'm sure thousands of others will be too, once they become legally approved. I could get more light out of a pair of wax candles than I could with the original Halogens before I upgraded them for some better road legal halogens.
