2006 Peugeot 407 4 speed AT
alialsukar
Unread post by alialsukar »
What is needed to replace the 2006 Peugeot 4 speed AT (ZF 4HP20 ) with a 6 speed AT (AM6).
x 6945
Re: 2006 Peugeot 407 4 speed AT
Apart from the gearbox and Gearbox ECU, the correct wiring, fittings, gear selection controls and wiring loom (s), possible BSI, Engine ECU and ESP / ABS configuration changes as a minimum. Also, the driveshafts are different and I think the AM6 was only fitted to the ES9A petrol engines.
