C5 jerking while driving on D
gian7
Unread post by gian7 »
Citroen c5 x7 2011 2.2 150kw automatic transmission
Citroen c5 is jerking while driving on D mostly 2-3-4th gears, who is understand it’s good nozzles parameters or not? Thanks.
https://imguh.com/image/QDQGW
https://imguh.com/image/QD4og
x 6955
Re: C5 jerking while driving on D
Sorry, I can't read the language on the documents, but when did you last change the transmission fluid?
gian7
I changed the gearbox for other reasons 2months ago, but nothing changed like jerking. In the photo 1 2 3 4 means nozzles.
x 6955
You should have some fault codes if the engine is stuttering - or at least some stored fault codes in the log if using Diagbox. If you have these pop them up with your VIN
gian7
I will try to find out the problem, and will back with info:) thanks
