DS5 H4 Hybrid - Loud thud from rear when regenerative braking
BnD1212
I have a 2012 DS5 h4 Hybrid 2.0L TDI. We have had the car a couple of months and it starts and drives well, but over the last few weeks it has developed what can only be described as a 'Loud Thud' coming from the rear when you let of the throttle and the car goes into 'regenerative mode'. It also feels sometimes that the car is being pushed on by the battery charge side when you apply the brake. It does not happen every time, but when it does it sounds quite severe. I am looking for some advise on just what it may be.
- x 3283
Re: DS5 H4 Hybrid - Loud thud from rear when regenerative braking
Hi, and
to the Forum. I cannot offer you any advice, other than to wait until somebody who has DS5 knowledge chips in.
Dormouse
- x 696
Hi and Welcome. The Hyrbrid4 system has a different feel under Regen depending on the level of charge in the Traction Battery and the feel is just like there is no brake effect when you lift off - ie, it feels like it is sailing on when you expect retardation. Check the charge level and if it is high to full you might not get Regen Braking. Disconcerting at first but perfectly normal, you just need to plan braking normally. Regen is not there all the time so you will have to adjust and learn this trait.
The thud is not normal and could be a driveshaft or damaged suspension. I strongly urge you to get it checked as soon as possible.
Dormouse
- x 696
Are you using Auto setting or Sport setting?
BnD1212
Hi Dormouse,
Thanks for your input. As far as the Regen side goes, i believe that is working as it should. I am definitely feeling the 'Braking / Regen' affect when lifting off. My main concern is the 'thud' coming from what sounds to be the rear axle area. The strange thing is it doesn't occur every time.
The car is driven mostly in the Auto setting
Dormouse
- x 696
Hi again. The car is much smoother, refined and quieter in Auto but can be "clunky" in Sport/ Manual. In Auto, Regen and battery usage balance out and you rarely get a full Traction battery. It does happen sometimes and you get caught out at roundabouts or junctions with the sailing on effect. In Sport or 4x4 you are more likely to fully charge the Traction battery quicker as that is how it is set up and more often so the lack of Regen braking occurs more frequently.
The rear suspension and motor cradle are well made and give a good ride with noise/vibration suppression, so any thuds from the rear are very out of character and need examined.
Dormouse
- x 696
A loose exhaust can give a solid thud occasionally. Worth a check.
