Alternator issue
MarkyD1977
Alternator issue
Unread post by MarkyD1977 »
Hi all.
I have questions...
Is the voltage regulator that is bolted to the alternator (valeo) on a 2010 Pug 5008 unique or coded to that ECU?
Is it worth replacing the voltage regulator of alternator codes are still present after changing the alternator?
Finally, in the event that I were to buy a used ECU, what is the score with fitting, coding etc... Is it a main dealer job?
Thanks in advance.
x 1056
Re: Alternator issue
Unread post by wheeler »
MarkyD1977 wrote: 01 Oct 2021, 15:47
If you are talking about an engine ECU dealers or the Peugeot dealer diagnostics system can't recode a used engine ECU.
Option 1 Would be to sent the original & 'new' ECU to a specialist to get it cloned.
Option 2 would be to get a used ECU, BSI & a working key all from the same car as the are a matched set. Be aware though if the mileage stored in the 'new' BSI is higher your instrument panel will inherit the higher mileage.
