C5 2.0 HDI 136 Turbo Replacement
aneesh84
x 29
Unread post by aneesh84 »
After siren like noise since last 2 years, finally the turbo seems to be leaking engine oil since the exhaust has white smoke.
I was looking to buy a CHRA from ebay and give to a garage for replacement.
https://www.ebay.com/itm/143675081037?h ... Sw6V1fK9Sn
Any advises or precautions?
Is it necessary to change the oil feed pipe to turbo, or it can be cleaned ?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
Gregor
x 16
Re: C5 2.0 HDI 136 Turbo Replacement
Unread post by Gregor »
hi.
I bought this: https://turbospareparts.eu/chra-core-ca ... 2494252-2/
Works fine for last 100kkm. Just cleaned the hoses.
Driving Citroen is a diagnose!
aneesh84
x 29
Thanks.... did you just buy the cartridge and replaced the core yourself, or give the turbo to some professional service to calibrate, test and change the core? is it a complex operation?
How did you clean the hose?
C5 2005 2.0 HDI 138
Gregor
x 16
I did it my self. The biggest problem for me was the access to remove turbo. All the rest done at kitchen table with home tools. Just carthridge replacement was needed.
Gregor
x 16
I did some turbo dissasembling in the 90's on R5 GTt.... so it was an easy job for me to replace CHR. If you are not used to such a work youtube can be helpful or just take it to the garage.
