2003 Renault Scenic 2l 16V Auto Only Reversing.
GerhardPretorius
New User
Unread post by GerhardPretorius »
I have a 2003 Renault Scenic 2l 16V automatic. It only reverse. No forward movement.
When R or N selected, the car reverse. If D, 1, or 2 selected it feels like the car is in neutral (can be pushed).
As I understand it has a DP0 / AL4 auto box.
It seems to be a common issue, or at least similar.
Some forums indicate F3 Brake band can be broken. But to verify you start vehicle and selects D. Then remove Fuse 3 (gearbox fuse) then the car will be naturally in 3rd Gear. Then you can drive to repair shop.
Lot of people found it useful. And confirmed working.
But in my case, my car still only reversing.
What tickle me is that even in N it reverse.
Hence, I'm lost now and need more help.
Please assist.
