I have a lot of problems with my cactus. Engine 12 80 hp 2014 With a normal ride of 80 in 5 gears, it showed me engine failure warling. I stopped the car and started it after 5 minutes and it showed me no errors on the meter or screen. The car is normally driven, perhaps less responsive. It has 50k transported. I have it for 2 years. I didn't get any errors with the torque program, and 6 errors with the car scenario. 2 years ago, the timing belt and water pump were replaced. There is enough oil. Antifreeze is clean. Im asking for help. I am attaching a statement of errors. Thanks.
Car Scanner ELM OBD2
DTC report
Selected brand: Citroen
============1==============
U1218
Raw code: D218
ECU: Engine control unit#3
Status: Pending fault present
============2==============
P0300
Raw code: 0300
OBDII: Random/multiple cylinder(s) - misfire detected
============3==============
P0A3B
Raw code: 0A3B
OBDII: Generator - over-temperature condition
============4==============
P1632
Raw code: 1632
OBDII: Smart Alternator Faults Sensor/Circuit Malfunction
Citroen: Smart alternator faults sensor/circuit malfunction
============5==============
P0011
Raw code: 0011
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
============6==============
P1336
Raw code: 1336
OBDII: Crank / Cam Sensor Range / Performance
Citroen: Crank/Cam sensor range/performance S2000PM1/2 - High misfire on several cylinders ME7.4.5. Combustion misfiring on unspecified cylinders.
============7==============
U1218
Raw code: D218
ECU: Engine control unit#4
============8==============
P0300
Raw code: 0300
============9==============
P0A3B
Raw code: 0A3B
============10==============
P1632
Raw code: 1632
============11==============
P0011
Raw code: 0011
============12==============
P1336
Raw code: 1336
Citroen c4 cactus 1.2 80horse power 2014
- x 1493
Re: Citroen c4 cactus 1.2 80horse power 2014
You need to clear all the codes and see what comes back. I have a recollection that random misfires on this engine are non uncommon, but the cause is not apparent, and the solution is to replace the engine....
