Periodic stop of daytime lights, compartment fan and rear window wiper. Fast ticking from the blinker. Xantia.
NorwegianMan
Unread post by NorwegianMan »
Daytime running lights and compartment fan always fall out at the same time. The rear window wiper often does not switch on when I turn on the switch, but works properly when it switches on.
Occasionally very fast ticking from the turn signal relay even though I do not use the turn signal. Then the turn signal works properly when I use the switch.
Could all this be caused by a poorly grounded cable somewhere? If so, where should I look for the fault? The engine starts and runs properly.
XANTIA (X1) 1.8 i 16V
