In the family we have a C3 Picasso 2012 with a semi auto gearbox. Now and then we receive gearbox fault in the display. We have a fault code P0948, which says, relay stays in open position. The readout says, elec pump motor control fault. The motor is sitting on the oil pump which gives pressure to clutch and gearchange operation. Can anyone tell us where the relay is, or if it sits inside the motor?
Regards
Steen Jorgensen
C3 Picasso ETG 6G gearbox fault
steenschalls
- x 6956
Re: C3 Picasso ETG 6G gearbox fault
Ok, so here's the diagram for your vehicle.
Have a look at 1660 on the diagram which is the Piloted Gearbox ECU. Look at the Pin 1 of the 12 Pin Black connector at the bottom row, which as per the fault code is suggested you check.
| Fault Code: | P0948 |
| Description of Fault: | Electro-pump unit electric motor control fault: Relay jammed open. Open circuit or short circuit to positive or short circuit to earth (Pin 1 of the 12-way connector of the ECU) |
| Conditions for Fault to clear: | No faults for 1 second |
| Downgrade Modes whilst Fault is active: | If the vehicle has the Stop and Start system : Stop and start function deactivated |
| Symptoms: | Warnings:
| Suspect Areas: | Frequent causes:
steenschalls
thank you, can I ask you to confirm some of the components? Ex 1669, 1633 etc
regards
Steen
regards
Steen
