Ds3 cooling fan not working
Haydar123
Unread post by Haydar123 »
Hello I have a Citroen ds3 1.6blue hdi I have a engine fault coming up saying vehicle repair needed I have replaced the fan and it is still not working any suggestions to what I should do thanks
x 6950
Re: Ds3 cooling fan not working
Why would you replace the fan based on this message?
The vehicle needs diagnosing, preferably with Diagbox to determine what the fault codes are. If you already have them, then put these up along with any other info you have.
Haydar123
The fault code is P0495 and it says electric cooling fan unit I have changed the fan and resistor 3 times now I don’t know what it could be can someone please help me out
