Xantia S2 smokey HDI
froggy
- (Donor 2026)
- x 4
Hi, my S2 HDI, chucks out clouds of black smoke (when cold) in first and second gear. when the engine"s warm , its fine. sometimes I get injector rattle! anybody any ideas? cheers Terry.
Reason: Modified Thread Title to Identify Vehicle
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
froggy
- (Donor 2026)
- x 4
Re: Xantia S2 smokey HDI
maybe the intercooler needs taking off and cleaning ? Terry.
Terry
electronmirror
- x 30
I've just had similar problem on my Xantia HDI (110HP RHZ engine) although mine was fine until up to working temperature when it belched black smoke. It also lacked power.
The problem was an inch long split in the intercooler rubber pipe right where it joins the metal stub of the inlet manifold, this resulted in lack of boost and consequent over fuelling and black smoke.
Temporarily fixed with tape, boost has returned to a pleasing level and the black smoke is no more.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- x 1746
That makes sense: black smoke usually means too much fuel, or not enough air.
froggy
- (Donor 2026)
- x 4
cheers
Terry
- x 1489
In my garage is said pipe... you can't easily fit an aftermarket solution, as IIRC it's different bores at each end. If you're interested I'll dig it out and make sure it's still OK, then see how much it would be to post it (not heavy, but it is rather long!!)electronmirror wrote: 15 Sep 2021, 13:59 I've just had similar problem on my Xantia HDI (110HP RHZ engine) although mine was fine until up to working temperature when it belched black smoke. It also lacked power.
Temporarily fixed with tape, boost has returned to a pleasing level and the black smoke is no more.![]()
froggy
- (Donor 2026)
- x 4
Terry
electronmirror
- x 30
Hello Richard,
Yes I am interested.
I did notice the difference in bore between the main part of the pipe and the end where it fits onto the inlet manifold. Initially I looked at various suppliers of silicone hose and concluded it's a bit of a palaver to home brew something that will fit and do the job properly so an original hose would be great.
Thanks,
Ted
Thanks,
Ted
Ted
electronmirror
- x 30
Hi Richard, have sent pm re the pipe, not sure if you've seen it yet.
Ted
- x 1489
