Xantia HDi Air Con not working
courier
Unread post by courier »
I have recently bought a 1999 Xantia HDi, the problem is when I switch on the air con unit the dashboard indicator light comes on but nothing else happens. Can anybody help?
davey
Unread post by davey »
unfortuanately there could be many things wrong with the system. probably the best thing to start with is to make sure there are no obvious things wrong - fuses, fittings etc.
If all appears ok the best thing to start with is to first verify you have enough refridgerent/pressure in the system (this is a dealer or a/c specialist job but not that costly) as a/c on cars does require periodic recharging. a/c must also be used occasionally just to keep the seals in good order. you may be lucky and only require the recharge ......
Tebster
Unread post by Tebster »
Have a look at the separator usually located on the left hand side of vehicle if looking into engine bay from the front.
It is a cylinder type object with two pipes and a wiring plug connected to it, there should be a sight glass in the top, if this is empty then it needs a recharge, if it looks green or full then your problem lies else where.
Can you hear the pump click in when the aircon switch is pressed ?
courier
Fuses and fittings seem ok,can,t hear the pump click in when the air con is switched on.Except for an occasional bubble I can,t see any fluid in the separator.
markxant
Unread post by markxant »
hi courier if its the same as 19td behind the battery is a black fusebox inside there are 4 relays (i think its 4 without looking) anyway the mauve on works the air con could be dirty contacts or a duff relay costs about a tenner from main dealer hope this helps
davey
as tebster mentions no fluid in sightglass will be a problem, with most a/c systems there is a low pressure safety switch preventing operation. you can still have fluid in the circuit but not enough to operate the system.
