Suspension
KennyW
x 165
Suspension
Unread post by KennyW »
Where is the height adjustment setting in the suspension ecu?
My ecu is suspension ecotec
C3 1.4 petrol (SWMBO)
x 6950
Re: Suspension
You can only programme in the values after measuring and doing the calculations as the values don't correspond to measurements if that makes sense.
But this should be available once you have run the Global Diagnostic, selected the ECOTEC suspension ECU and confirmed the selection, where it will take you into the other menus for related operations.
KennyW
x 165
Re: Suspension
Okay, which one to select repair or maintenance and what is it called
Kenny
