xantia fuel flap stuck shut
xantia69
help fuel flap servo failed cant fill car up how do i get to fuel cap without breaking flap
JohnD
- x 72
NiSk
Don't know if this will help, on my '93 XM TD12, there's a discription in the user manual of opening the fuel cover manually from inside the boot. Not that you've got an XM, but maybe if you look in your instruction manual?
Unfortuantely, I havn't got the XM with me today so I can't look it up for you.
//NiSk
//NiSk
Gavin1
User manual suggests you contact your dealer - I did and was told if you removed the carpet etc from inside the boot there was a flap .. well I couldn't find any access flap and sods law the fuel light was on and had been on for a whle when it refused to open! In the end having no choice I prised the flap open with a wide blade screw driver using a protective piece of wood to prevent the blade denting/damaging body work / paint. Fortunately the pin bent rather than breaking the fuel flap, once open I straightened the pin with pliers and lubricated the mechanism and it has worked ever since, with no damage to the flap of body work.
