My Citroen c5 2.0 hdi nav 2009 as started revving at about 1100 revs when idle since I replaced the copper washer seals on my injectors. The only thing that makes it drop to normal is when I press the brake until I release the brake it goes back to 1100.
Any help is appreciated
Cheers
High revs at idle
stagsmad
Re: High revs at idle
Hi all Slight update after fiddling around today it appears that I only have to move the brake pedal a mm to make the revs drop to normal and it is only the brake pedal that effects it.
As before any help appreciated
