Gearbox oil change warning - not that bolt, NO!
captainkephart
x 8
Unread post by captainkephart »
Hi All,
100k miles, time to check / change gearbox oil ...
Hahaha #-o
Yes, there's the filler / level plug (nearsidetop right just above front brake disk);
Is that the drain plug? Looks like it, starts to unscrew .... mmm, er this drain plug seems rather long ... but oil is coming out.
Hang about. The book said a plug with a square hole ... this is a normal bolt head. STOP!
I had actually been undoing the bolt that holds the reversing gear actuator lever ... if you take it out completely there will be a clunk as it drops inside then it's gearbox change time, not just oil!
The drain plug is hidden among the engine mounting ... OK, I was careless!
Marc, have you some cutaway diagrams of the gearbox you could post? Assume it's the same on most of the manual boxes?
Ciao, Capn K
PS: The drain plug needs an 8mm square allen key (or a suitably ground down 10mm hex one).
The secret of happiness is freedom - and the secret of freedom is courage ...
x 6950
Re: Gearbox oil change warning - not that bolt, NO!
Here you go:
(1) Drain plug.
(2) Filling and level plug.
(3) Breather.
N.B. :The breather orifice can be used for filling.
Gearbox Oil Quantities
  • Gearbox empty: 1.9 litres. (So this would be when new without any oil).
  • After draining: 1.8 litres.
So be careful here - you should measure the amount you remove and replace with the same quantity.
Here's the parts diagram for further clarification:
(10) is the Gearbox Breather, (11) the Gearbox Breather Protector and (12) the Gearbox Filler Cap.
