06 Picasso 2 litre auto
oscar
x 8
Unread post by oscar »
Hi need to change car as ULEZ Killed!
Looking at 06 2 litre petrol exclusive "Auto" 95k miles What's the Verdict on the Auto boxes as spoke to Edwardes citroen spares they didn't rate auto box and did read on here was some issues!
x 1053
Re: 06 Picasso 2 litre auto
Unread post by wheeler »
The AL4 box isn't too bad to be fair. The most common issue the suffer from is problems with the electrovalves in the valve block. The good news is this repair is not the end of the world & can be repaired in situ without the need to remove the gearbox.
oscar
x 8
wheeler wrote: 23 Aug 2021, 21:41 The AL4 box isn't too bad to be fair. The most common issue the suffer from is problems with the electrovalves in the valve block. The good news is this repair is not the end of the world & can be repaired in situ without the need to remove the gearbox.
Hi never went with it in end it went for £720 was 2 litre 16v exclusive model.Cheers.
