C5 wiring diagram
Dunkah
x 11
C5 wiring diagram
Unread post by Dunkah »
Hi, does anyone know where I can get my hands on a wiring diagram for a c5 2008 hdi tourer wiring diagram or full manual
Thanks in advance
x 6945
Re: C5 wiring diagram
What system do you need a wiring diagram for - and please be specific. We can help with occasional specific diagrams, just pop your VIN up with the system you need, i.e. Fuel Injection system, Suspension System etc.
Dunkah
x 11
Ok, the vin is
And it’s the suspension system I need
Many thanks
x 6945
Here you go:
A lot of the codes are on the Wiki here: https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
But here are the main ones to get you going:
1524 : supply cut-off relay /
7739 : central electronic block motor
7769 : suspension buzzer
7749 : luggage compartment height selector /
7715 : suspension control unit
7703 : rear body height sensor /
7702 : front body height sensor /
7747 : front suspension electrovalve
7748 : rear suspension electrovalve
x 1052
Unread post by wheeler »
Dunkah wrote: 23 Aug 2021, 14:49 Hi, does anyone know where I can get my hands on a wiring diagram for a c5 2008 hdi tourer wiring diagram or full manual
Thanks in advance
Get yourself a copy of Citroen SEDRE. This is the system that the dealers use for wiring diagrams. Its all online now but you can get a backup copy that does vehicles up to around 2013.
You can either get it from ebay or it can be downloaded if you have a search around.
Unless you run it on a virtual machine it needs an older 32 bit system like XP or windows 7.
Dunkah
x 11
GiveMeABreak wrote: 23 Aug 2021, 16:14 Here you go:
Excellent stuff! Thanks for that. Much appreciated
Dunkah
x 11
wheeler wrote: 23 Aug 2021, 17:24
Thanks in advance
Cool, I’ll look into that. Many thanks
x 3296
You might want to have a look on the Easy Diagnostics on-line shop. They have it for £10, and covers vehicles up to 2013;
https://www.easydiagnostics.co.uk/produ ... tilanguage
Dunkah
x 11
Hell Razor5543 wrote: 23 Aug 2021, 18:04 You might want to have a look on the Easy Diagnostics on-line shop. They have it for £10, and covers vehicles up to 2013;
Thanks, I’ll check that out 👍🏼
