stuck in reverse
gloworm
stuck in reverse
put the car into reverse today (citroen synergie) when i came to put it into 1st the gearlever wouldnt go anywhere except neutral had to reverse the car around the block to park it up. externally everything on the gearbox is where it should be . anyone got any ideas before i trailer it to a garage[:0]
AndersDK
NiSk
I Had the same problem with my ('93) XM TD12 a number of years ago. Stuck in reverse. I managed to back it round to a friends grease pit and by wiggeling the selector rods around from underneath (some of which sat rather loose), lifting up a front wheel and rolling it back and forth while someone else rattled the gear lever inside the car, I finally got it back into neutral. I then inspected the gear change linkage more thoroughly and discovered an inordinate amount of play, so I ordered a new main selector rod and bellcrank. It turned out that Citroën had modified just these parts, so I was supplied with a mod-kit. Once this was fitted, all excessive play disappeared and I havn't had the problem again.
Most of th eplay came from the bellcrank, which swivelled on a pivot screwed into the steering rack housing. The mod-kit had a much better solution which distributed the forces better.
//NiSk
//NiSk
gloworm
