Xantia sunroof drains
Bruce H
My Xantia hatchback with the factory sunroof gets a wet back under-seat and floor, whilst the boot seems dry. This happens when parked level. I’d like to check the drains but have no idea where they run - anyone know?
GS by several
Xantia SX by several
Contact for the Australian Citroen GS; GSA and Birotor Register http://australiancitroengsgsaandbirotor.weebly.com/
- x 1487
Re: Xantia sunroof drains
googlesearch?cx=000757428655895309399%3 ... mit=Search should give some clues. I think that Citrojim once did a pictorial guide, but I can't immediately locate it.
- x 1487
Bruce H
Thanks enormously, this second link is exactly what I was after. I’d obviously used the wrong terms for the forum search, as I was at the end of the fifth page of results and still hadn’t found this.xantia_v6 wrote: 21 Aug 2021, 05:24 See: viewtopic.php?p=214173&hilit=Drain+sunroof#p214173 and viewtopic.php?p=296295&hilit=Drain+sunroof#p296295
GS by several
Armidillo
- x 274
Bruce I presume you have checked the sealant in the shallow gutter behind the tops of the rear doors? Longitudinal cracks developed in what I assume was the original flexible sealant on my SX wagon, which I'm sure resulted in water under seats and in the rear footwell, as well as water in the boot. Took me ages to find - just wasn't looking in the right places.
One of the first things I checked was the (non-genuine) sunroof - it was (and is) sealing perfectly.
Cheers
Alec
Cheers
Alec
