Diagbox Live data
peugoetrobbie
Diagbox Live data
Unread post by peugoetrobbie »
Hi
What does 'diesel output delivered by the pump reference value' mean?
Is that what the high pressure sensor is reading?
Many thanks,
Rob
x 1060
Re: Diagbox Live data
Unread post by wheeler »
Many of the parameters will have an actual value & a reference value. They reference value is what the ECU is expecting to see at that given time, actual as you have probably guessed is what the ECU is actually seeing at that given time.
peugoetrobbie
Many thanks.
Do you know what 'measured injected flow' is? And does it have a reference?
Cheers Rob
