I've got a 1.9d Citroen ZX (with a Lucas pump) that has sat unused for a while but now won't start. It turns over fine and no smoke is emitted from the exhaust. I thought it just needed priming, but despite this it was no different. With loosening the injector pipes it seems there is no diesel getting to the injectors as you turn it over. There is fuel getting to the pump though. I suspected a stop solenoid issue so cut off the armour and replaced the original with a single terminal solenoid (which does work when applying 12v) but there is still no fuel emerging from injector pipes.
Summary:
- The car (lucas pumped XUD9 N/A) hasn't been used in approximately a year
- The primer bulb goes hard when squeezing
- Stop solenoid is new
- Fuel is at the pump inlet and return when loosening them while priming.
- No fuel is getting to injectors when turning over the engine
Could it be a case of air being very difficult to bleed out? Is there anything that I've overlooked or is this pointing to the fuel pump being the issue? Is there something that is known to go wrong with the fuel pump resulting from a lack of use?
Many thanks
Mark
XUD not starting - no fuel to injectors
- x 1746
Re: XUD not starting - no fuel to injectors
Fuel does need to emerge from the injector pipes, as you say.
Try repeatedly squeezing the priming bulb while cranking.
Check that fuel can be sucked up from the tank - the first stage of the pump would normally do this.
If necessary, provide the pump with a temporary source of fuel, eg from a small container or bottle.
moizeau
- x 423
Also when you prime the pump have the ignition turned on to open the stop solenoid
Pete
- x 1746
...and check that 12v is still reaching the stop solenoid during cranking (use test lamp on it).
- x 1240
Give it a squirt of easy start, that should spin it up fast enough to purge the fuel system - if that's the problem.
- x 1061
Yes, very important point. Lots of ignition controlled 12v feeds drop out on cranking.white exec wrote: 31 Jul 2021, 10:22 ...and check that 12v is still reaching the stop solenoid during cranking (use test lamp on it).
Xsarahdi
Thank you for the replies.
I had already tried repeatedly squeezing the priming bulb while cranking but will give it another go. I did have the ignition on when priming and had already tried applying 12V to the stop solenoid directly from the battery in case there were any issues with the wiring. Still couldn't get it started.
I will try a small container of diesel as a temporary fuel source and get some easy start to give that a go.
Mark
Mark
2005 C3 1.6 HDi 110 VTR
2003 Xsara 2.0 HDi 110 SX
1999 306 1.9 TD Meridian
1996 ZX 1.9 D Elation
moizeau
- x 423
If after all that it still doesn't want to play take the stop solenoid back out and check it on the ignition to visibly see that it's working, you may have to earth it. You could also remove the rubber nipple, solenoid rod and spring then replace it. You'll need to use the manual stop lever to turn the engine off (or stall it in 4th). Be careful the spring will want to make a bid for freedom.
Pete
