1.6HDi DV6C 9HL injector voltage - what is normal?
mcdos
(Donor 2021)
Unread post by mcdos »
It would be really helpful if someone with a vehicle having a 1.6HDi (DV6C 9HL engine) with diagbox could take a look at the control voltage of the injectors bank 1 signal in their ECU (HDi_SID807_BR2) - when the engine is ticking over. I'm really struggling to find out what the norm for this is. My ECU indicates 225-228Volts at idle.
This may be normal, but if it is too high, it could be the source of some random faults I'm seeing and would likely damage any replacement injectors.
