308 sw high beam always on
mrvf
Unread post by mrvf »
Hi Guys,
my 308 sw 1.6 hdi from 2008 have new fault :( high beams are always on, pull the fuse to swith of.
if i pull stalk to high beam i see blue indicator in dash to come on and off but lights are always on
anyone with the same problem?
i read on google that ptoblem can be bsm or comm2005...
x 1459
Re: 308 sw high beam always on
Unread post by xantia_v6 »
If the warning light is controlled correctly, then the bsm is the likely problem. If you can find a matching part at a good price it may be worth a shot.
You should get a diagnosis with diagbox. There may be a fault code stored, but at least it should tell you whether the com2000 is commanding the lights to be on.
mrvf
im waiting to receive my diagbox, read with autel and abrites avdi and didnt see nothing.
other light are ok, can swith on and off. only high/dipped beams.
i will wait the diagbox to see
x 1052
Unread post by wheeler »
I would agree that if the telltale on the dash is working correctly then the coms unit is probably OK.
Sounding like BSM. Might be worth pulling it out & checking for water ingress. Have you tried tapping the casing of the BSM with a screwdriver handle or similar? If its a sticky relay it may free it.
mrvf
Car was stopped 3days, the battery with 6years its dead.
Buy new battery, installed, put fuses to try to make some diagnostic and the lights are off 8-[ 8-[ 8-[ 8-[ 8-[ 8-[
Now i dont know if its ok or if its intermitent fault :oops: :twisted:
