ABS Errors C1331, C1326, C1387
Digital-man
Unread post by Digital-man »
Hi Guys
Peugeot 307CC 2008 HDi Diesel
VIN VF3**************[VIN obfuscated, can be read by forum staff]
I have an ABS brake problem that I'm struggling to fix and apreciate any help I can get.
Below are the error codes.
C1331 Front Right Wheel Speed sensor signal fault
C1326 Rear LH Wheel Speed sensor signal fault
C1387 Fault wheel speed sensor asleep
The car was fine before all the brake pads and discs were changed at the garage. To try and resolve the issue the mechanic changed the rear discs twice to eliminate an ABS ring issue. He also changed the rear Left Hand and Front right sensors. But still the exact same errors are displayed. All errors have been cleared using diagbox but still no joy. Does anyone have a wiring diagram for ABS wiring as i'm thinking this could be the reason for the faults.
Really scratching my head on this and apreciate any help/advice
x 6957
Re: ABS Errors C1331, C1326, C1387
Pop your VIN up (automasked) so I can relate these faults directly to the type of ABS system you have.
