Fuse 8 blowing
Jonny555
Fuse 8 blowing
Unread post by Jonny555 »
Hi all I have a partner van 06 1.9d
When I turn key on it blows fuse 8 under bonnet don’t think it’s the starter as it blows just when it go’s to on position sometimes u can start van up and can run for few days before blowing and stopping has anyone any ideas cheers
MarcinW
New User
Re: Fuse 8 blowing
Unread post by MarcinW »
Hi there. Did you ever find what was the problem as I have exact same issue and cannot figure it out..?? Thanks. M
PaulC5
x 696
Re: Fuse 8 blowing
Unread post by PaulC5 »
Possibly the insulation on a wire has worn through so shorting it to earth as the switch is used to make fuse 8 live. If you know what fuse 8 serves you can trace the wiring after the fuse. Could also be a faulty component after fuse 8 or water ingress.
