c5 exclusive error code p0098
uselessgrandad
Unread post by uselessgrandad »
i have error code P0098 Intake Air Temperature Sensor 2 Circuit High
i replaced the air temperature on the air intake but i am still having the same error
at around the same time i developed a fault with the cruise control i dont know if they are connected
anyone have any ideas on the P0098 error
many thanks in advance
x 1061
Re: c5 exclusive error code p0098
Unread post by wheeler »
The year of the car & which engine you have would help.
Do you have any warning lights on or any running issues aside from the cruise control fault?
uselessgrandad
car is 2009 it is a 2lr diesel
x 3298
Hi, and :welc: to the Forum.
If you were to post up the vehicle VIN here it would be possible for forum staff to find out exactly what you car had when she rolled out of the factory, which will then help with the error code. The VIN will (for security reasons) be obscured so only forum staff can read it (like this, for example; VF7**************[VIN obfuscated, can be read by forum staff] ).
The reason the cruise control is not working is because the relevant ECU has detected a problem, and taken the cruise control off line. Once the main problem has been resolved (and the ECU recognises this) the cruise control will be available again.
uselessgrandad
do i just put the vin number in plain text?
x 3298
Yes, indeed. The forum software will then (because of its configuration) recognise it as a VIN, and will obscure it (in the way it did in my previous post). Don't put in any spaces; just how it appears on the vehicle and the V5 logbook.
uselessgrandad
my vin number is
x 1061
wheeler wrote: 06 Jul 2021, 19:41
uselessgrandad
i have engine warning light and the car runs as good as it always has
