The 2005 C5II I have does not have ISO Fix child seat anchors. Does anyone know that part number or know if the factory anchors are bolted on or welded on?
I finally am close to finish restoring my C5II in China and want to use it for a long road trip with my daughter. Thus, I want to be able to mount her child seat into the C5II.
By the way, the other day, my daily use Peugoet 407 which the child seat is normally mounted to, I just realized only the passenger side rear seat have the ISO Fix mount while the driver side do not. Those are welded on, but is there a part number also? I would like to add it so next time my daughter's friend can go out with us using her own seat.
Since UK vehicles have ISO Fix long ago, I thought to best ask people on this forum.
Thanks.
C5 II ISO Fix child seat anchor... Part.
AlvinCitroenC5
- x 3
- x 6945
Re: C5 II ISO Fix child seat anchor... Part.
There are isofix mountings for the rear outer seats on the C5 MK I and MK II. The anchoring brackets are in the join between the seat cushion and the seat back. If you put your hand in and move it side to side you should feel the 2 rings for each outer rear seat that the isofix seats clamp onto.
There is no Isofix on the front seat on these models - so if using an alternative child seat in the front, you must disable the passenger airbag system with the key.
AlvinCitroenC5
- x 3
Unfortunately, the C5 I have that was exported to China does not have the ISO Fix anchors. That is why I am looking for a solution to determine if the factory anchors are welded in or bolted in. And if there is a part / part number where I can purchase it. I hope someone can shed some light on this, as I am not satisfied using the 3 point belt to secure the child seat.
- x 6945
I can't see that is the case. Your car was built in France (at Rennes la Janais) and they have ISOFIX points on the 2 outer seats. They are not visible normally - you have to dig your hands in to feel the rings, but they will be there as they won't make a separate seat frame chassis mounting just for export for this sort of thing.
Don't expect to find anything fancy, there will just be a metal hoop located towards the rear outer seat edges that is buried deep into the gap between the seat and back cushion somewhere, but they are not separate parts and not shown which confirms it's not a variation or option.
AlvinCitroenC5
- x 3
Marc,
Thanks. I found it. I thought it would be under the seat cushion. But it is in the seat back.
- x 6945
I knew it was there
