My temperature gauge increases with speed, it rises to around half way and then falls back to normal once I have slowed down. Any ideas on what could be causing this would be most helpful.
[:D]
renault laguna temperature
grattsim
lonbk
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by grattsim</i>
thanks for the idea, I've fitted a new thermostat not so long ago. Could it be electrical?
My Haynes manual says that is caused by a faulty voltage regulator
grattsim
lonbk
I read that, as far as I knew the regulator was all part of the alternator? Is there another one as the alternator seems to be working fine?
You need to test the output voltage. Conect a voltmeter to the battery
and start the car. the voltage should remain between 12 to 13 regardless of engine speed
grattsim
philhoward
Are we not thinking about the instrument voltage regulator (feeds the instruments); if your fule gauge goes up when the temp gauge does, then it's at fault.
14.3V sounds a little high to me; where did you measure it? At the battery or the alternator output itself? May be about right for actual alternator voltage; i'd expect to see around 13.5 at the battery itself.
Another possibility is a weak water pump, or blocked radiator. The rad may be helped by flushing the cooling system.
grattsim
philhoward
arry_b
I think you're barking up the wrong tree looking for an electrical problem I'd expect to see 14.4V at the battery terminals just after you've started the car and you're not far off that(although as Phil says - keep an eye on the alternator and the battery electrolyte level).
If the thermostat is new (and is in the right way up), then a radiator flush is next on your list.
Does the rad have any cold patches when the engine is warm?
grattsim
grattsim
grattsim
could it be possible that if air was entering the system then this could cause it to heat up with the speed increase, and then as I slow down the air escapes. As it can cool down within 100-200 yards once I slow the car down. Such an annoying problem!!! Although my obsessive need to find the problem doesn't help...
mikgram
