citroen c5 suspension only goes low and normal position
vasilus_rs
hi, all next issue with my c5 just noticed that suspension goes only low and normal position when I press the button it shows on the dashboard that it's going up from normal position I can hear the pump but the car doesn't move. any idea? thanks
- x 3296
Re: citroen c5 suspension only goes low and normal position
I would check how much LDS there is in the reservoir. Bottom her out first, wait a few minutes (to allow things to settle down), and then undo the cap and have a look. There is a 'grating' inside the top of the reservoir, with (around the neck) some vertical slots. The LDS should be between the lower and upper slots.
vasilus_rs
I've done that, but no change.
- x 1055
Does the suspension self level then return when you put weight on then off each axle?
Do you have access to diagbox?
Could be a body height sensor but i would have thought an fault warning would come up on the dash.
vasilus_rs
Found the issue, I just moved the front height sensor bracket on the bar 2mm, and now it's fine going up and down + showing correct on the dashboard + before the front end was a bit higher than the rear one. Thanks for the help guys.
