Hi. I have a 2012 Scenic 1.6 Petrol. I had the cambelt changed recently including the dephaser pully. Before I had this changed and also since, I get the code P0011 and a message check anti pollution system.
When the cambelt was done so was oil and filter change, although I didn’t buy ‘renault’ spec oil, just Shell Helix.
I have read that code P0011 can be thrown up by sludgy oil. As it has had fresh oil, can anyone suggest what I can try next?
The car has only done around 60k miles
Scenic 1.6 petrol code P0011
- Dormouse
- My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly) - x 666
Re: Scenic 1.6 petrol code P0011
Hi. P0011 is associated with camshaft timing I believe. Did you set the new cambelt to the correct timing marks?
- My Cars: Citroen C3
Renault Scenic 1.6 petrol 2012
Citroen Relay 2008
Alfa Romeo 147
Morris Minor Sidevalve convertible
VW beetle Karmann Convertible
Citroen 2CV - x 1
I didn’t do the camshaft. However, the same code came up several times prior to the new cambelt being fitted. I have a cheap OBD scanner to read and delete faults
- Dormouse
If the engine was running with this code before then it is up to others better placed than me to chip in with their thoughts. cheers
