C4GP Sill rusting
discv
x 24
C4GP Sill rusting
Unread post by discv »
My c4 grand pic. is just starting to show signs of paint blisters on the driver side sill, and being realistic I know I can be sure of things to come!
So, I am at a crossroad. A bit of filler and some black paint over stone chip is not my style.
The original sill looks to be part of the body shell. Service box seems to show a repair panel- and if I'm right about this- it would be a major task to fit.
This corrosion issue is very common on all Pics. since 1999.
What's my options?
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
x 6954
Re: C4GP Sill rusting
As far as repairs go - there are both an outer sill and an outer section under the front door - both repairs require extensive cutting out at specific areas, the requisite repair parts, electrolytic re-zincing, sealing and spot welding. So if I were you, I'd perhaps get them rubbed down at a body shop, treated, primed and painted as a first possibility - so a check on what is actually going on - as it may just be some surface rust or moisture that is causing the paint bubbling and nothing to worry about if treated.
discv
x 24
Thanks Marc- I think your advice is good. The problem I have to overcome is that here in South London it will be near impossible to find a body shop that has the first clue.
There are still a few skilled guys about- but they operate in the area of vehicle restoration, where the rules are 'it costs what it costs' !
x 6954
No worries - it may be worth looking at an accident repair place - that the insurers use if you have one near you. They can often give you a quick quote and may be less than you think.
