Renault 19 ecu wiring diagram
This is the Forum for all your Renault Technical Questions, Problems or Advice.
Isac2
(Donor 2021)
Post by Isac2 »
Hi
I have an old -94 R19 1.8 Cabriolet ph2 and thinking about replacing ecu with diy pnp standalone (Speeduino).
Originally It has got a Magneti Marelli/Weber single point ecu system for which I haven’t found wiring diagram to match. Anyone in forum got it?
Ecu is MM IAW 8R.30 30pin connector and Weber integrated throttle body.
I am interested about ecu plug wiring and how ignition coil is hooked up, does it have separate driver somewhere or is it driven direct from ecu.
Isac2
(Donor 2021)
Re: Renault 19 ecu wiring diagram
Post by Isac2 »
Connector is 35pin, not 30.
