Hi
I have an old -94 R19 1.8 Cabriolet ph2 and thinking about replacing ecu with diy pnp standalone (Speeduino).
Originally It has got a Magneti Marelli/Weber single point ecu system for which I haven’t found wiring diagram to match. Anyone in forum got it?
Ecu is MM IAW 8R.30 30pin connector and Weber integrated throttle body.
I am interested about ecu plug wiring and how ignition coil is hooked up, does it have separate driver somewhere or is it driven direct from ecu.
Renault 19 ecu wiring diagram
Isac2
- (Donor 2021)
Re: Renault 19 ecu wiring diagram
Connector is 35pin, not 30.
