C5 MK1 ABS Pump part number / other models
sifaan
Unread post by sifaan »
Hi
There seems to be a malfunction in my ABS pump where some internal problem leads to gearbox fault and I am trying to source a replacement
It would be helpful if I could get the part number as well as what other models (Citroen or Peugeot) used the same pump - so if buying used I could get a more recent unit, and especially with Pug I may then be able to source it in Sri Lanka rather than get it from UK and ship it
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
x 1056
Re: C5 MK1 ABS Pump part number / other models
Unread post by wheeler »
The complete block is 454154 & the ECU on its own is 454280. Looks like the only Citroen model to use this is the C5.
If looking for second hand i dont know if these numbers will help you much as most breakers use the component manufaturers numbers printed on the component.
