Peugeot 407 Hdi 2.0 Headlight Assembly
barrymurphy
Unread post by barrymurphy »
Is the headlight assembly on a 1.6 hdi 407 the same as the 2.0 hdi 407?
My 2.0 has a bad looking passenger side unit, the right side looks much newer and I can get my hands on a 1.6 hdi passenger unit.
Also does bumper need removed?
Regards
Barry
moizeau
x 429
Re: Peugeot 407 Hdi 2.0 Headlight Assembly
Unread post by moizeau »
Can't help on the parts but yes the bumper needs to come off. You need to make a special tool to unclip the headlight from inside the wing and also undo the bolts, 3 each side I think again from under the wing, before you 'ease' the bumper out from it's clips otherwise they will break.
The special tool is a piece of thin bar with a 90 deg bend on the end.
It goes through it in the BOLs and is quite straight forward.
Pete
x 6954
They will be the same as long as they are not from the Coupe version and not the discharge light type (Xenons).
