Citroen C3 - Fuel pump replay location?
kubby
Unread post by kubby »
Hi All,
I wanted to perform a compression test on the Engine and was wondering where is the fuel pump relay located on my Citroen.
I want to disconnect the relay before performing the test.
My car model is Petrol C3 (A51) 5 DOOR SALOON 1.6 VTi 16v 120. It's a 2011 model.
The VIN # is VF7**************[VIN obfuscated, can be read by forum staff].
Thanks in advance.
Kubby
x 1438
Re: Citroen C3 - Fuel pump replay location?
Unread post by xantia_v6 »
The fuel pump relay is probably integrated into the BSM and not separately removable. A better idea is to pull the fuse. Look in the handbook, it should identify that one.
kubby
xantia_v6 wrote: 09 May 2021, 08:35 The fuel pump relay is probably integrated into the BSM and not separately removable. A better idea is to pull the fuse. Look in the handbook, it should identify that one.
Thanks for the reply. I had an inkling but wasn't sure. The bonnet fuse box - fuse F10.
Thanks again for your guidance. I really appreciate it.
Kubby
