C4 Picasso 2014 Semi Auto | can't select gear please help
acipurk
Unread post by acipurk »
Hello
My C4 Picasso can't select in to gear. It's semi auto (R, N,A, M). Car start normal without any warning lights. When I select to gear 1 it shows change from N to 1 for second and jump straight back to N. Same thing with A or M option. After few attempts gearbox fault come on screen, just for second and then disappear. I have uploaded video ok YouTube so you can see symptoms -
I have plugged to Autel MaxiPro MP808 and only 1 fault code come up U1213 - permanent fault - Communication fault between the ABS/EPS ECU and Electric Power Steering ( EPS ) (DAE) ECU .
Anyone had same problem ? Any suggestions where and what to check?
Any advice much appreciated 🙏
