Partner II 2013 Brake Lights always on.
wiggy
Unread post by wiggy »
Hi all,
I have a 2013 (63) Peugeot Partner II which is used as an animal ambulance for my own business. For the last week or so I have had to drive with the brake lights constantly on, as it's needed for work and the only vehicle i can use! I can't seem to pin point the issue or the location of the relays to see if this is at fault. Any help would be greatly appreciated.
Regards,
Wayne
x 1056
Re: Partner II 2013 Brake Lights always on.
Unread post by wheeler »
Sounds like the brake switch may have either come out of its holder or failing that it may just need re adjusted. sometimes if your foot accidently lifts up the pedal when exiting the vehicle for example, it can knock the plunger out of adjustment. That would be where i would start looking.
A 2013 model will be a Partner III
