Hi everyone,
Need a part for a Xantia 1.8i 1996. There's a circular unit around the steering column, behind the steering wheel from which wires lead to the airbag unit in the steering wheel. It's basically designed to allow a circuit despite the turning movements of the steering wheel. It comprises of thin copper circular strips sandwiched together to keep electrical conductivity, to bridge the wires going into it to the ones going to the airbag unit, inside a black plastic circular casing.
One of the thin copper circles had a segment borken off and was able to move around inside the casing which broke the wire off it, so I repaired as best as I could but was unable to stop the movement caused by the missing segment which usually would have pressed against the casing and kept it in one place.
Car had been fine for weeks like this - no more airbag red LED on airbag unit lighting up when turning steering wheel - but now my father is right now driving back from the airport and has phoned to say smoke is coming from the steering wheel. I'm worried about risk of fire, airbag inflation and excessive damage to the wiring.
That aside, what is this part called so I can get another one ASAP and where might I find a supplier if GSF don't stock it?
Thanks for all help,
Help identifying part name please...
cit-tech
Dave Burns
I would'nt worry about the car I would worry about your father, its not safe to drive in that state and he must keep well away from it, if you are covered by a breakdown service I would get it recovered, or at least they will disconnect it all to make it safe.
I don't want to seem like a scare monger but things are potentialy that bad if wires are smoking in that area.
Mostly refered to as the "Air bag or steering wheel rotary connector".
Dave
Dave
blueboy2001
JamesQB
- x 5
blueboy2001
