Xantia front anti roll bar rubber bushings
aerodynamica
x 214
Unread post by aerodynamica »
I have a terrible creaking coming from these bushings at the front. I want to know if these rubbers are supposed to firmly grip the roll bar and the twisting is all done by the rubber (just like the lower arm bushings) or is the roll bar supposed to rotate and slip within the rubber.
I wonder because the creaking suggests they are slipping in the rubber and I don't want to consider rubber grease or anything before I learn of the correct relationship. Haynes book is completely vague on this (doesn't even tell you!)
Graeme M
aerodynamica
x 214
Re: Xantia front anti roll bar rubber bushings
Thinking a bit further, I wouldn't expect the roll bar would be designed to slip within the rubber because that constant shearing action between the rubber and the metal would surely wear out in short time! So surely the rubber is supposed to be firmly gripping the roll bar and the rubber twists like the lower arm bushings. Someone on the FB group suggested rubber-compatible grease but that just doesn't seem right?
Graeme M
x 1750
If wear on black 'rubber' ARB bushings is a problem, I've had really good results using polyurethane ones (from companies like Powerflex). The RAV4 used to eat the OE 'rubber' ones, but some PU replacements just soldiered on.
These are fitted with a smear of PU grease around the RB.
aerodynamica
x 214
Thanks Chris, I'd love PU ones for ALL of the Xantia's terrible lower arm rubbers!
Graeme M
x 8070
The hold and locate the ARB in position Graeme but don't 'flex' in the conventional way... They act more as bearings and I've never known them wear...
The ARB should be held firmly but be free to rotate.
Some sort of lubrication may help. Does the creaking stop when it rains? It was always my experience of several of my Xantias!
tich731
Unread post by tich731 »
Is the creak from the ARB bushes?
I have just cured a serious creaking on the OSF of my XM. It felt like it was coming from the strut, but further examination revealed it was the droplink. The upper balljoint had become amazingly stiff. A new Lemforder droplink has cured the problem.
2009 C6 2.2 Hdi Exclusive Gris Fulminator
1999 XM 2.0 TCT Balmoral Blue Nacre
1987 2CV6 Rouge Vallelunga
1979 2CV Fourgonette (by Villevans) Cormoran Gris
1981 Midas Silver
1972 D Special Black (gone but not forgotten)
