308cc Window
markdknott
New User
308cc Window
Unread post by markdknott »
Hello to all
I really need some advice please.
My wife has a Peugeot 308cc 2013 model. When the drivers door is opened the window drops a few mm. The window is supposed to stay down untill the door is closed. However it is going back up before and casuing the window to be on the outside of the rubber seal. Ive checked the passenger side and it works perfectly.
Has anyone experianced this or know how this can be resloved.
Thanks in advance
x 1056
Re: 308cc Window
Unread post by wheeler »
Might be worth checking for broken/damaged wiring in the harness that goes between the body & the door.
x 1450
Re: 308cc Window
Unread post by xantia_v6 »
It would probably be worth getting the car checked on a diagnostics system that can read the state of the door switches. It could still be a broken wire to the switch (which I think is located in the clock mechanism).
It would also be worth (as a no cost option) trying a BSI reset. See viewtopic.php?t=61997, after which the front window anti-pinch will need resetting before the roof will work.
