2013 Jumpy sticky steering servo. Getting better when warmed up...
Axa
Unread post by Axa »
Any ideas what causes this problem? When starting up the servo is hardly working at all at least turning right. Fluid level is ok. After short drive it improves successively but keeps being "notchy" turning right from center. If going slow and keep turning quickly between full left and right it disappears. Then back again next startup. Any ideas? Could it be a piece of rubber that blocks a valve or something?
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
Axa
Re: 2013 Jumpy sticky steering servo. Getting better when warmed up...
Fluid level is good. But the fluid is black, so obviously needs to be renewed. But I suspect that's just a waste effort and cost to do now when something is wrong?
Or can the problem be a sticky valve due to bad fluid?
