1997 P Reg 306 D Turbo.
Can anyone specify a procedure to determine the reason why the central locking on my son's 306 does not work. All 3 doors will lock on the turn of the key but none locks centrally either by key nor the remote key fob. All we've done so far is put new batteries in the key.
Any info would be greatly appreciated.
Central Locking - Not Locking
Homer
- x 16
Phil Harmonic
Homer
- x 16
Phil Harmonic
Homer - no, it was working when he bought the car and as far as he can remember (it's not been working for some time now), it stopped working 'all of a sudden' - it didn't go dodgy first but stopped immediately. What I'm looking for is a method to test 1. the sensor;2. the conrol unit;3. the lock motors and anything else involved. I suspect that because the system is completely dead that it's the control unit and I have half a suspicion that when my boy and his mates installed some ICE in the car, they ran some cables down the side of car where the control unit is installed and they may have affected it in some way. What do you think. I could just take the seat out, pull up the carpet to have a look, but I'd like to know what to do when I get there. If I have to replace the control unit - will the existing transmitter still work; does the sensor have to change as well. Do we need a full set of everything, I suppose.
Dave Burns
The micro switch in the drivers door lock is known to cause problems like this, though you should get some action even if it unlocks its self immediately.
Find the controller for it, if its anything like the citroen one you can undo it and push the relay contacts together manualy, that will tell you if everything is working ok downstream of the controller.
I think the reprogramming of the reciever from the plip is the same as citroen, a freind had one done on a 94 306 though he didn't see it done it only took a few seconds so I would imagine its the same procedure, ignition on accessory position and just hold the plip close to the bubble and fire it for a few seconds.
Dave
Dave
Phil Harmonic
