C4 ABS / ESP
Mrtattoo
C4 ABS / ESP
Unread post by Mrtattoo »
Good evening all this thread been going a while
Currently have a brake switch fault
Abs esp diagram please would be very helpful
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Thanks 😊
Reason: I've split this into a separate topic as you have a different vehicle with different systems
x 6955
Re: C4 ABS / ESP
Here you go:
Most component codes are on the wiki in sections here:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
Mrtattoo
Re: C4 ABS / ESP
Thanks 🤩
Mrtattoo
Re: C4 ABS / ESP
Great stuff👌
can I see voltage readings for these wires?
I Have 3.5 volts at grey wire coming from brake switch is this right?
Thank you
