2017 C3 Flair. Driver side window air vent
Gazzalene
The lateral moving vents on the airvent have become unattached. How is the section of vent removed from the dash please? Might be able to get the mechanism back if i can get the unit out.
- x 6955
Re: 2017 C3 Flair. Driver side window air vent
The units are removed with basic trim removal tools - you may have to take the end corner air vent out first, then there will be a few plastic clips that hold the fascia air vent surround in place. Once this is off, it should expose the central vents, which you should be able to see how to remove. But if you're a bit nervous about snapping anything - get the dealer to sort it as they are probably more adept at removing this type of trim as they are similar on many models of this age and later.
